Can you type in exact angles to measure and construction tool?
Faster loading of texture library?
Bump. Can anyone help please? Used GSG textures after a long time and faced the same issue. -
54
Thank you very much for checking. We just realised that compression we used for audio track leads to automatic lower db output than original. It will be resolved for future videos1
