Clones Constrained to Other Clones
Go to solution Solved by bezo,
Hi - I've got some noise moving a grid of cubes up and down. I have another grid of spheres and I want them to float over the cubes and follow the movement in synch.
Problem  is cubes being moved by scale on y parameter. So if I use same shader noise the scale of my spheres will be effected, but I don't want that. So I tried the same shader noise on the sphere cloner's 'y' position parameter, but can't really get to synch perfectly. Futzed around a bit w/ constraints but they wanted to look at original object position (instead of adjusted moving cloner positions) and its really just a face of cube moving not entire cube.
Anyway, can someone suggest something?
LogoTower_WIP.c4d
Follow up - Secondary motion accomplished with shader effectors children of object I want to move (which is in turn child of the spheres that I set to not display, ie. cones just inherit spheres motion up and down) and then shader set to object mode with random 'H' rotation. works. thks.
    1. 220
    2. 3
    3. 2
    4. 52
    5. 3
