11
Thanks. That is a known issue that can happen on undo or some other actions, will be fixed.1 -
Sure, here it is. It is working fine again with a fresh C4D instance. scene_nodes_update_issue.c4d -
11
I checked the other 2 videos and it's the same for me. I have my audio settings set up as follows, and this is fine for most youtube videos I watch (or any other audio related things). The audio of the intro is fine and clear, the narration just is too quiet.
Posted by Willem Zwaan,
Potential Solution
Reputation Points
Go to this post
Posted by HiFly,
Potential Solution.
Reputation Points
Go to this post
Posted by HiFly,
Reputation Points
Go to this post
