Sketchbook Kingcoma's Sketchbook
: D You are seriously overestimating my capabilities. I found some pieces of obscure math paper and managed to convert it into nodes. -
i use my plugin UV splinemapper for this, we extra made this for curved or polygonal folder elements in building streets, furniture etc: https://3dtools.info/shop/spline-uv-mapper/ it generates a UVW map tag, that can be rendered in any engine and the result can be also rendered in other c4ds that not have this plugin. one controlls the fow of the UV via a simple c4d spline. no unfolding or bodypaint needed;) -
Hi All, As there seem more and more Chaos Vantage users, i want to point out that all our materials beside the few V-Ray dirt concretes materials, also work in Chaos Vantage real time rendering. Like for example from C4D V-Ray via live link to Vantage!
