Cinema 4D Indie version - What's your opinion about this?
95 members have voted
1. Should there be a C4D Indie version?
Yes, Cinema 4D is too expensive compared to other packages and I've switched to another package or I am planning to do so.58
Yes, Cinema 4D is too expensive compared to other packages but I'm not planning to switch to another package.28
No, Cinema 4D is not too expensive and there's no need for a Indie version.4
I'm not sure about this / I don't care.5
Can I trouble you to check the audio on other few videos and see if you are experiencing the same? -
1
Looks like some refresh issue - can you post a scene file please? -
8
1
Hi, I encounter a weird recurring issue with Scene Nodes, it randomly stops to update the result of nodes operations. Please look at the capture below for a clear demonstration of the issue. As you can see the problem is gone if the Nodes Modifier is pasted in another scene. Could it be some kind of cache issue ? Thanks
