Cinema 4D Indie version - What's your opinion about this?
95 members have voted
1. Should there be a C4D Indie version?
Yes, Cinema 4D is too expensive compared to other packages and I've switched to another package or I am planning to do so.58
Yes, Cinema 4D is too expensive compared to other packages but I'm not planning to switch to another package.28
No, Cinema 4D is not too expensive and there's no need for a Indie version.4
I'm not sure about this / I don't care.5
