Hello from Finland!
@stephan laub Do you have a video anywhere showing this in action? -
1
Faster loading of texture library?
Bump. Can anyone help please? Used GSG textures after a long time and faced the same issue. -
54
Since the spline is pulled from edge segments - it goes from blue to white and then blue to white again. This is showing point order and it ideally is blue to white once over the whole spline run. What happens if you try to reorder the points and set a new first point? (right click on the spline, the ordering options should be near the bottom of the list). Does this change anything?
