Flatten polygon selection based on normals
Go to solution Solved by zipit,
Hi @bjlotus,
6 hours ago, bjlotus said:
I'm calculating the mean (i think) using the "normals_avg"  variable. I add each cross product inside the for loop and then divide by the amount of polys selected. This was a quick example so I just calculated normals the way I remembered when I used to play with other software years ago. I'm not even checking if the polys are a triangle hehe... your GetPolygonNormal function is certainly more elegant. I compared the results and, while not always exactly the same, they are pretty close.
This was not me be pedantic about terminology and you are computing the mean and the normals. I was just pointing out that you were just computing the normal for one of the planes in a polygon - unless I am overlooking something here. But for quads there are two, one for each triangle in the quad. Below is an illustration of a quad which I did manually triangulate for illustration purposes. You can see the vertex normals in white (which are each equal to the normal of the triangle/plane the lie in). And two plane normals in black, one for each triangle. The actual polygon normal is then the arithmetic mean of both plane normals.
So when you just pick one vertex in a quad to calculate the polygon normal, i.e., simply say one of the white normals is the polygon normal, then you assume that both tris of the quad lie in the same plane, i.e., that the quad is coplanar. Which of course can happen, but there is no guarantee. Quads are today usually quite close to being coplanar (and not that comically deformed as my example), but you will still introduce a little bit of imprecision by assuming all quads to be coplanar.
Cheers,
Ferdinand
  • Replies 11
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
Hi @bjlotus, hi @Cairyn,   there is one problem with your normals calculation. You calculate just a vertex normal in the polygon and then declare it to be the polygon normal 😉 (your variable
Hi @bjlotus,     This was not me be pedantic about terminology and you are computing the mean and the normals. I was just pointing out that you were just computing the normal for one
If you want to flatten a group of polys, you need to define the plane you are flattening them against. That is pretty arbitrary; you could use a plane perpendicular to the average of all normals, or m
Posted Images
17 hours ago, zipit said:
Hi @bjlotus,
So when you just pick one vertex in a quad to calculate the polygon normal, i.e., simply say one of the white normals is the polygon normal, then you assume that both tris of the quad lie in the same plane, i.e., that the quad is coplanar. Which of course can happen, but there is no guarantee. Quads are today usually very close to being coplanar (and not that comically deformed as my example), but you will still introduce a little bit of imprecision by assuming all quads to be coplanar.
Cheers,
Ferdinand
Hi @zipit!
oh, now I totally understand what you mean! (pun intended 😄)
Thanks so much for the clarification; that would explain the tiny differences when I compared the results using your function.
PS: it didn't sound pedantic at all!
Best,
Jon
ABOUT US
SUPPORT
Tickets
Purchases
