Sketchbook Evan Alexander Sketchbook Vol 04
In your original post, it looks like the spline is a really two splines connected together - it goes from blue to white and then blue to white again, so I assume you're connecting smaller segments together? What happens if you try to reorder the points amd set a new first point? (right click on the spline, the ordering options should be near the bottom of the list). Does this change anything? -
I checked the other 2 videos and it's the same for me. I have my audio settings set up as follows, and this is fine for most youtube videos I watch (or any other audio related things). The audio of the intro is fine and clear, the narration just is too quiet.
