Using S24 Pose Library On Xrefs
Go to solution Solved by onebraveegg,
I'm making quite a large project at the moment which requires Xrefs of the characters. The characters faces are also rigged with S24's pose library feature, but when I import an Xref character into a scene, unfortunately, the pose library no longer works.
I was wondering if anyone knew why this was the case? And if there is a solution? I've tried importing the Xrefs in various forms but I'm not having any success sadly.
Any help would be greatly appreciated! Thank you!
  • Solution
There was a couple of issues in the character rig that were confusing the issue, but once I'd fixed those separate issues, this problem became quite clear. So, just in case anyone else makes the same mistake that I did, all you have to do is just make sure to import the Xrefs with 'Name Space' set to 'None'.
By default, the pose Library will only recognise exact naming conventions, so perform these steps in order to ensure that your naming conventions are identical when you import the Xref.
  • 4 months later...
    1. 462
      Cinema R25 Release
    2. 3
    3. 462
      Cinema R25 Release
    4. 462
      Cinema R25 Release
    5. 462
      Cinema R25 Release
