R25 Expectations
I fear there is a bit of a hangup on some important but minor difference in the handling of composite  data,  while it is a difference between Scene Nodes and Xpresso it is not a functionally or systematically relevant one, but a minor issue that i think will be resolved over time.
The real differences are in how they both work.
Xpresso is mainly used to control the current state of objects based on previous states and some user added logic. For that it is called an expression system, because it creates dependencies by applying expressions. These expressions can not create objects or geometry, they can only reference and control existing objects, though TP is actually an exception from this rule.
Scene nodes on the other hand usually live in a single frame, to make them dependent on previous states you need to employ extra measures like the memory node. Creating things however is at the very heart of scene nodes and they can also directly manipulate the created information, something xpresso does only in a very limited way.
  • Replies 137
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
Sadly this is the truth now. I also know many developers who have left C4D plugin development. With the cost of subscriptions and the fact that nobody wants to pay to help develop a plugin to its full
+1 on your entire post. Since the release of R21 I seem to have noticed quite a decline in plugin purchases ... that was until I entirely stopped the business due to costs rising way over benefit
Are they really?... Xpresso is a basic, easy, clear piping of position X into position Y that mortals can comprehend.   Scenes nodes is.... decomposing a global matrix, splitting a matrix in
Posted Images
These are two setups that should make the difference clearer. The Xpresso setup is something that you actually can not create in scene nodes in this way currently. You can create something that gives a similar effect, but not the exact thing.
The scene node example on the other hand can not be replicated within Xpresso, since it includes the creation of new geometry. Even with TP you would not be able to replicate this since you would still need a single original cube from outside of the node system.
Thanks Srek for the explanation,
But I think the discussion is about something different. It looks like there are two groups that just are not able to really understand each other, as most of the arguments where exchanged multible times in this thread.
- One Group tries to enplane, what scene nodes are, and that they are superior to xpresso and therefor xpresso will get obsolete.
- and the other group states that it likes xpresso for ist easy usability and because it is a tool that makes skripting accessible to non coders. And that a more powerfull tool might be of absolutely no use for them if is to complex for them to learn.
What I read out of the discussion is, that every one now has accepted, that scene nodes is technically something different then xpresso, that it is much more powerfull and that it can reproduce everything that xpresso can do.
But what I don't really can read from this discussion is a real concept to make these complex scene nodes as accessible as xpresso or even better accessible. I read That it all is just a UI thing (It will not be as easy as that) or that node groups can be produced as new asset (which is really cool, but doesn't help when you have to find it between ten thousand other nodes, that form every function of a already quite complex program).
I from my standpoint I think that it is highly advisable for the technical side to try to understand the fears of some of the users here and use this understanding to form something better but at least as easy to use as xpresso. I assume that there are already some thoughts about that, but I think, that the most powerfull tool is of no use if you can not utilize it and as sceene nodes is as complicated as the whole of C4D, as we know it,  Maxon needs to put as much brain into the usability as they did with the whole UI that we have right now. Otherwise it is not much more then a API.
best regards,
Jops
Simply study the scene node, and you will find that it is actually easier to use and logically better than XPRESSO.
If there are multiple cases where the scene node is more complicated than XPRESSO in the actual exercise, please post them so that everyone can judge what happened.
best regards,
Jops
If you split it like that then i have to say that neither group has it right. Xpresso and Scene Nodes are two different tools with different purposes, one can't replace the other.
Xpresso is easier to use (UI/UX issues aside) since its scope is smaller and it avoids most of the complexity involved since that part is left to the object manager and the (old) scene graph it creates.
Scene Nodes are way more complex than Xpresso because they replace what the Object Manager does, they create the (new) scene graph. At this point in development the Scene Manager is just starting to try to enable users to work with the new scene graph on a level that is similar to the Object Manager. The Scene Nodes represent something the users never had direct acces to before, only serious plugin developers faced similar complexity when creating own objects. It is no surprise that not every user is comfortable with this and it is really important to understand that noone expects that every, or even a majority, of users will ever be comfortable working based on Scene Nodes.
The current situation is just an artifact of the need to build up a new system from the bottom up and the decission to make this available to users early (Tech Demo). The alternative would have been for Maxon to keep this development under wraps for several more versions until the Scene Manager is in a state to replace the OM, but that would also mean that we at Maxon would not get very valuable feedback from users, something that is of high importance given the nature of these changes.
So please everyone, give us feedback, but keep in mind that Scene Nodes are not the final main interface for everyday use by most users.
As for the future of Xpresso, i see the need for something very much like Xpresso, but based on Scene Nodes, once the Scene Manager reaches a certain degree of maturity. We might as well call it XPresso 2.0, but it would have to be something completely new that mainly has the purpose in common with old Xpresso. A lot depends on the experience we gain from current development and the feedback we get on it.
Thanks Srek again 🙂
you sum up pretty much my assumption of the situation.
I very much like that maxon makes the scene nodes available early, but the purpose of scene nodes and the future outcome (which UX will differ quite a lot from now) seems to have the potential to be communicated better (even though you as a person in this forum obviously are doing you best 🙂)
This discussion here is a nice example of the feedback you are hoping to get :). Maybe not the kind you expected but never the less useful.
Underneath all the discussion of scene nodes vs. Xpresso, three very important points are being completely missed:
  1. C4D's legacy for ease-of-use.    Sorry, but the Maxon team has a 35 year history of making the difficult very simple with such tools as MoGraph, Xpresso, and the Object Manager.
  2. Scene nodes being rolled out as a "tech-demo" immediately sends the connotation of complexity -- just by its name alone.  Add to that examples of complex nodal trees to do things that are easy to replicate in MoGraph and you have a hard sell to a user base that has grown comfortable with easy to understand drag and drop functionality.
  3. Adding insult to injury is the hard line tone coming from Maxon:  "Scene-nodes is the FUTURE.  GET ON BOARD OR BE LEFT BEHIND".    Really?  Very interesting marketing strategy there Maxon.  "Telling the user" rather than "listening to the user" is never good for a company.  Some people have even stated that there is a bit of shaming going on relative to Scene Node adoption (Are you smart enough for Scene nodes?).  Well that has to stop and the arrogant pugs who behave that way need to be taken to task.
When you combine these three points together, I do believe that what the average user is internalizing is this message from Maxon: "We are throwing out everything that you have grown to love about C4D in favor this new architecture ".    That is not good.
My recommendations is to continue the development of Scene nodes as it is smarter way to proceed but it should always be marketed/communicated/demoed as  what it is being developed to be - and that is an "under the hood" capability.  Maxon needs to reinforce the message that you can live quite comfortably with C4D and all the benefits of the new architecture without ever having to look at a scene node.   Making statements that Xpresso is going away in favor of scene nodes does not help.  The last couple of posts were very informative in explaining how Xpresso and Scene Nodes address two completely differently workflows so my assumption is that the functionality of Xpresso is still required but a future version of it will exist under the Scene node umbrella.  If true, that is the message that should be communicated and every effort should be made to make the new scene-node equivalent of Xpresso look and act like Xpresso does today.  Sorry...I know it is more work but 35 years of training brought us to where we are today so you proceed at your own peril if you don't respect that.
In summary, Maxon needs to reset on how scene nodes is being marketed.  You do have a hard sell on your hands and these forum discussions are not helping and thus my recommendation to reinforce that it is an under-the-hood application.  One way to quickly get that point across is to develop new and more highly requested tools (such as proper symmetry) as complete scene-node constructs.  "Hey, we know you all love all the power of this new tool, but did you realize that its 100% built on scene nodes?"  If you do that a few times, or replicate some of the cool modeling modifiers that were coming out of Maxon Labs (like extrudifier or coons mesh, etc) as 100% scene nodes and people will quickly catch on.  Add to that the ability for all those dis-enfranchised plugin developers to switch to creating scene-node developed tools in a way that protects their IP and removes some of the headaches for licensing, marketing, etc via a Maxon developed portal (hey...how about the ultimate greeble tool in scene nodes?) and now you start flipping the script on how Scene nodes is being perceived by the user.
Just a thought.
Dave
Thank you Srek, that sums it up really well.
I think opening up development for feedback is really smart.
Personally, I hope C4Ds revamp will bring me (in broad strokes):
Performance
The more artistic decisions per hour, the better.
Ease of use
With more performance under the hood, please consider presets
that mimick real-world-behaviour for ... everything 🙂
A lot of times, I just want to pick a preset and be done.
Apart from presets: You guys are UX masters, so just keep going.
Complexity as needed
Then again, the new UI and "realistic presets" should allow us to
drill as deep as we like, whenever we need a really custom solution.
A marketplace for pre-packaged Stuff
It would be really cool if the new scene nodes would allow devs to
easily build complex stuff that more artistically  oriented people like
me could buy from a central place. Preferably, a curated Store,
or maybe even directly from the asset browser.
Thanks 🙂
    1. 3
      Corona Renderer 7
    2. 3
    3. 175
      Houdini Tests and Impressions
    4. 3
    5. 175
