How to exclude objects from certain reflections?
Hello,
so I have a sky with an environment texture on it, a ground and a car.
I want the sky to only appear in the reflections of the car and not in the reflections of the ground. How do I do that?
I can't disable "Seen by reflection" in a Compositing tag on the sky because then the sky doesn't appear in ANY reflections. It should only affect the car.
Thanks
  • Solution
You can use the Exclusion tab in the Compositing tag to tell Cinema that you don't want the sky reflecting in an object or group of objects that you drag into the field.
    1. 0
    2. 4
    3. 3
      Corona Renderer 7
    4. 4
    5. 175
      Houdini Tests and Impressions
