Cinema 4D Can I stop deformers from disappearing when I 'make object editable' or export?
Solved by Cerbera,
Can I trouble you to check the audio on other few videos and see if you are experiencing the same? -
1
Looks like some refresh issue - can you post a scene file please? -
8
1
Hi, I encounter a weird recurring issue with Scene Nodes, it randomly stops to update the result of nodes operations. Please look at the capture below for a clear demonstration of the issue. As you can see the problem is gone if the Nodes Modifier is pasted in another scene. Could it be some kind of cache issue ? Thanks
