Cinema 4D Can I stop deformers from disappearing when I 'make object editable' or export?
Solved by Cerbera,
I checked the other 2 videos and it's the same for me. I have my audio settings set up as follows, and this is fine for most youtube videos I watch (or any other audio related things). The audio of the intro is fine and clear, the narration just is too quiet. -
I tried the first and last videos. The brief music is way too loud compared to the narration.
