Cinema 4D UV splitting apart
Out of curiosity I watched the first 10-15 seconds of the first and fourth video. I like that the intro to the video is short and simple. But the audio of the actual tutorial is quite low in comparison with the intro, I really need to crank up the volume to make it audible, and even then the quality is less then desirable. Please normalize your audio. -
7
220
Hi, thanks for the quick feedback and sorry for the delay. It's a spline extracted from mesh edges. The .c4d scene is in attachment, you'll find the setup and the original mesh from where the spline was extracted. Thanks for the example ! But I think it works in this case also because the cloned object is symmetrical In my scene the object has a front side that must face the "inside" of the curve. Don't bother too much if there isn't an easy solution to my issue, in the end I've just duplicated the setup to get the expected result. What is bothering me is that I don't have the issue on Blender when I reproduce the setup, so maybe I've missed something. Thanks ! cloner_spline_orientation.c4d
