22FPS Empty Viewport, Crashes. Specs: RTX 3090, AMD 5950X, Latest Studio Drivers
Go to solution Solved by Igor,
1 hour ago, BLSmith said:
Moving the camera around a bunch and clicking a few random buttons will make the program freeze as well.
Somehow I have some doubts this is a compatibility issue with R19.
Is the system running stably under load otherwise? Did you try to run Cinebench? Or Furmark? memtest would also be a good idea. Does the system have a well dimensioned power supply?
  • Replies 18
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
Good idea on this though thanks for the suggestion I'll float that to my boss.
Woops, didn't see that!
Oh, then you should give me a visit. Here in my machine the RAM seems dying currently. And I get all sorts of effects, I wouldn't have thought possible before. Even so strange I wasn't even suspecting
I'm with you here, except memory. There's only one way I've ever seen a system crap out with memory issues: straight up software crashes or complete system freezes. Unless he's running ECC memory (probably not) I highly doubt it has anything to do with memory.
Temperatures or power supply issues? Could be.
Just now, Igor said:
In that case all he would have problem with Windows and all SW included. I dont see how would this be only related to C4D if the issue is not in C4D itself.
Not necessarily. I've had cases where my slightly overclocked GPU would run game a just fine, but crash instantly on game b. Also constant crashes on Octane / Redshift. I even tested the overclocks with Furmark and it ran fine.
Computers are weird man, you can never generalize anything with this stuff.
Oh, then you should give me a visit. Here in my machine the RAM seems dying currently. And I get all sorts of effects, I wouldn't have thought possible before. Even so strange I wasn't even suspecting the RAM to be an issue. I only got onto that track, when system info suddenly reported to only have 28GB...
Anyway, I agree with you, memory is a far fetch.
No, not necessarily. (oopsy, too late)
Interesting. You learn something new every day, ey?
On 7/19/2021 at 2:18 PM, DasFrodo said:
How many objects do you have in your scene?
C4D chokes hard with many objects. Polys are no issue.
This is for an empty scene, but if I load my project:
  • From C4d:
  • Object: 5925
  • Polygons: 77322659
  • Memory: 3.75GB
On my other workstation with two M5000's and a GTX 1080 FTW (with Octane Live View off) I get a workable 20FPS with my project open. My .C4D project file save size is about 4GB. I am guessing some will make a comment about how insane this is, and if anyone wants to chat about how I can reduce this size in the future with a given STP file (I do have access to the engineer that has the ProE file if needbe), feel free to chat. That being said, the main issue right now is the low performance with even an empty scene.
Yes I play games on it 3-5 hours a day after work and it runs those great, granted I haven't tried gaming since I installed graphic studio drivers while trying to troubleshoot this issue.
12 hours ago, imashination said:
You have plugged the monitor cable into the graphics card right? ie. you haven't accidentally plugged it into the motherboard video output
Very interesting you should point that out. Yes it is connected via Display Port, but it is a 10 meter display port cable. Could that length effect it somehow? It's longer than a standard Display Port cable as the system is in another room to cut down on noise/heat in my bedroom while I'm sleeping + rendering.
The chances of me upgrading to the latest Cinema4D has increased from 0% to 50%, so fingers crossed that I'll be able to upgrade and test on the newer software. Otherwise, as it stands right now I'm at the office sadly and it's working good(ish) on my older hardware.
    1. 175
      Houdini Tests and Impressions
    2. 2
    3. 175
    4. 38
      Insydium Sneak Peek - xpBullet | Fused Discussion
    5. 175
