Align to spline not animated along displaced path
bryanfsmith
Hi Bryan
Couldn't make it work with the displacer, but you could use a cloner and the rate parameter as in the example below. You would need to make it a single path tho or you get 2 clones like below.
Also to keep the rate constant you should change the points to uniform.
Deck
AlignToSpline_0001.c4d
Hi There
You can try putting your spline (with displace deformer) inside a mospline and then use the mospline to guide your objec (align to spline)t. it will work like a charm.
cheers
14 hours ago, deck said:
Hi Bryan
Deck
That looks great, thank you much Deck!
13 hours ago, jbatista said:
Hi There
cheers
Many Thanks J Batista - will be taking a look at that!
    1. 0
    2. 4
    3. 3
      Corona Renderer 7
    4. 4
    5. 175
      Houdini Tests and Impressions
