Generating Number Sequences Using MoGraph with "00" before numbers
Go to solution Solved by jed,
Hi all!
I have a little problem with the mograph blend mode. As you can see in the screenshot, I want to number my cabinets with numbers from 001 to 150. With mograph I have succeeded but I cannot start with "001" instead "1" as the numbers in black. Is there any way to do it?
Thanks all
  • Solution
Assuming you're using Noseman's method of getting the text from the name, it's possible if you use python zfill and make the cloner editable -
import c4d
#Welcome to the world of Python
def main():
    global Output1
    Output1 = Input1.zfill(3)
zfill pads a string with zeros up to the max character count in brackets.
zfill.c4d
Noseman's method - Generating Number Sequences Using MoGraph in Cinema 4D - YouTube
import c4d
def main():
    global Output1
Unfortunately I don't know python..and dont't what do you do but it works! Thanks a lot!
Here's your 1st lesson 😀
I made a python node and deleted the ports (by default they are reals and Python is quite fussy about data types)
I made input and output ports data type string
code to be executed goes under def main(): and is indented by 4 spaces
the output variable is declared global so it can exist outside the main code body (where variables are local)
the = sign works a bit different to regular math. The RHS is evaluated and assigned to the LHS variable - Output1 is 'given' that value
zfill is a built in string command
the = sign malarkey is interesting because you can have apparently nonsense Python code such as
x = x + 1
which just increments x by 1
  • 1 month later...
Register a new account
Sign in
    1. 461
      Cinema R25 Release
    2. 461
      Cinema R25 Release
    3. 461
      Cinema R25 Release
    4. 461
      Cinema R25 Release
    5. 1
      Real teeth material
