Best Way to Tweak MoCap Data for Precision
220
52
April Fools is right around the corner. Expect: "Maxon merges with Adobe..." , "Insydium confuses themselves with their licensing so much they sell to Maxon", "Maxon releases C4D 2025, with new integrated particles, fluids and pyro 3.0"
