Studying a complex 3D model.
Jaee
Hi guys, I am trying to model a 3D sparkling water machine in C4D and struggling to create that cap part of it on the top. Could anyone kindly help me with this modeling? Attaching a C4d file I've done so far. Thanks!
WaterMaker Modeling.c4d
  • Solution
My primary advice here is 'build it from the same parts as it is in the real world. So that top section is 4 separate parts, though you can start them all from the same model. You just need to patch that top section in the way that is most helpful to your plans, which is like this initially.
So, as you can see, most of this started with disc primitives, and expanded from there with regular poly tools and techniques.
SDS gets you the curves of course and the box corners / control loops get you the control of them...
Thanks for explaining. Could you teach me how you created that? Is this the right way to start? Thanks,
Almost. I started like this with a disc, but with an inner radius set before I made it editable and split half of it off. We don't need the inner part of the circle because we want to design our own topology there and avoid all the triangles.
Thanks! To build the inner part of circle, should I select the inner edges of it and scale them down? or should I use the Polygon pen?
Don't do anything that creates triangles ! Always patch to quads, but how you do that is entirely up to you. I used bridge personally on that bit.... or just take this red line out to restore all the quads 😉
Thanks, I think I made it correctly. How did you make the other parts?
I have no idea of making the middle part.
I was kinda hoping you could see how to proceed by looking at my suggested topology above. But most parts are made from others. Consider this part here...
So I have started this by selecting the most of the perimeter loop on the existing centre piece then ctrl-scaled (or extruded) that out to get an outer loop. Then I split that off, and expanded it to square form, acknowledging the edge flow from the piece above to make sure my edges lined up and I was matching any control loops I had added there...
Could you take a look at what I've done so far? I think something went wrong...
Yep - that is the sort of SDS result we expect from a model that doesn't have any segmentation in the sides, and has uneven segmentation around the perimeter.
You also seem to have abandoned the building it from separate parts strategy, which is not a good idea if you are trying to make this realistic. Other than those things there is nothing actually wrong with the topology you have, just that it doesn't yet serve the purpose it needs to.
To be honest it is hard for me to advise further when I only have 1 tiny pic for reference !
Right...I feel that I need to restart from this. Could you help me with this further? Here is the link to the reference.
https://sodastream.com/products/terra?variant=31832071897130&utm_medium=cpc&utm_source=google&utm_campaign=Google_Shopping&gclid=CjwKCAjwqeWKBhBFEiwABo_XBp9MpZn-6xGYec-Wg-gaN8zOme8HcxxoptWVyF8OH-bmeHOqFHfkPRoCA44QAvD_BwE
WaterMaker Modeling_0001.c4d
    1. 0
      Hinge connector not working on organic shapes
    2. 55
      Houdini 19 - 11min Sneak Peek
    3. 0
      Blender tutorials
    4. 4
      jawset "reactions" evolution of turbulence FD ?
    5. 55
