How can I get a Layer's objects with Python?
11
Thanks. That is a known issue that can happen on undo or some other actions, will be fixed.1 -
Sure, here it is. It is working fine again with a fresh C4D instance. scene_nodes_update_issue.c4d -
11
I checked the other 2 videos and it's the same for me. I have my audio settings set up as follows, and this is fine for most youtube videos I watch (or any other audio related things). The audio of the intro is fine and clear, the narration just is too quiet.
