Substance Painter - 'Clear Coat'
@stephan laub Do you have a video anywhere showing this in action? -
54
11
Since the spline is pulled from edge segments - it goes from blue to white and then blue to white again. This is showing point order and it ideally is blue to white once over the whole spline run. What happens if you try to reorder the points and set a new first point? (right click on the spline, the ordering options should be near the bottom of the list). Does this change anything?
