C4D r25 questions
6 minutes ago, HappyPolygon said:
t makes it look like the function is intended only for sculpting
It IS mainly for sculpting, and adds a sculpt tag to the model when invoked !
  • Replies 16
  • Created
  • Last Reply
Top Posters In This Topic
On 5/9/2022 at 7:52 PM, Cairyn said:
You are probably using the normal scale tool. There is another, called UV Non-Uniform Scale Tool, which allows stretch and squash.
@allenhanford I would even try the UV Transform tool (in the menu of the texture manager (UV Mesh / UV Transform). Pressing shift while scaling allows for non proportional scaleing. And with this tool you can even see, what you are doing. 😉
3 hours ago, HappyPolygon said:
That means it' not always useful and they should brink back the Project Mesh command...
Er.... that is how that command has always worked ! It has never not been part of the sculpting workflow, and has never gone missing from any version of Cinema that I am aware of !
  • Customer
You are right. I opened R12 and found out that the tool I was using to project things was the Project Spline after all....
