Cannot have channels which depend on time
vitorcgi
Go to solution Solved by vitorcgi,
14 hours ago, Igor said:
This means that the node you are using cannot be animated or its channel. Can you screenshot the node network?
What I'm basically doing is putting all the layers together and mixing them into one(C RGB) and I use the out_texture scene data to do this, the parameters minimum (Y) for source (min) and maximum (y) for source (max)
and i dont know how to fix it, ive been trying to fix it for few days...
i know its seems a quite "basic" problem but im learning so
if u want more nodes screenshot just tell me
or if you want check it all the project, here is the link https://easyupload.io/1l2b3s
Thank you in advance
Regards
This screenshot below shows the node network where i mix the layers
Guest Igor
Like I said. Those parameters cannot be animated, so they dont work when you set a keyframe on them!! So if you remove the keyframes, the warning will be gone.
  • Solution
Thank you, it didnt worked so well but i found a solution, instead of pointing the parameters minimum (Y) for source (min) and maximum (y) for source (max) in scene data, i did it manually it worked i will for sure use ur tips later on thank uuu
  • 2 weeks later...
