Installing Octane Render for Houdini?
MJV
Go to solution Solved by MJV,
I have been trying without luck to install Octane for Houdini Indie for four months. The Otoy forum is absolutely useless, as is everywhere else I've searched. Has anyone done it successfully? I precisely followed the steps in this video but it doesn't work. Nothing shows up in Houdini. Anyone have any ideas?
Guest Igor
You need to make sure to use proper Houdini version with proper version of Octane. Make sure to check which is the last Houdini version that Octane supports. Also, I would assume you need Python 2.7 Houdini version...same is with Renderman, it doesn't work on Python 3
  • Solution
Hi Igor. I finally got it. First I was looking in the wrong directory (for some reason the houdini directory with the "houdini.env" was in the One Drive Documents file which I try to never use instead of the user Documents file) , then I had typed slightly the wrong syntax. Man that was a massive headache. Well I've leave this here for now. Maybe others will have the same problem.
