Relative spacing between clones
Can I trouble you to check the audio on other few videos and see if you are experiencing the same? -
Looks like some refresh issue - can you post a scene file please? -
8
Out of curiosity I watched the first 10-15 seconds of the first and fourth video. I like that the intro to the video is short and simple. But the audio of the actual tutorial is quite low in comparison with the intro, I really need to crank up the volume to make it audible, and even then the quality is less then desirable. Please normalize your audio. -
7
Hi, I encounter a weird recurring issue with Scene Nodes, it randomly stops to update the result of nodes operations. Please look at the capture below for a clear demonstration of the issue. As you can see the problem is gone if the Nodes Modifier is pasted in another scene. Could it be some kind of cache issue ? Thanks
