SDS Weight Tag R25
HiFly
Hi. I'm in R25 trying to use the SDS Weight Tag, but it is not working the same as in previous versions. I am adding the tag from Tags > Modelling Tags > SDS Weight. But doing it this way, the tag affects the whole object, not just my edge selection. In R25, how can I use the SDS Weight Tag to control my edge selection only? Thank you
  • Solution
No, you are doing that wrong. You would ordinarily never just put a weight tag on an object - instead you should create one by using the SDS Weighting TOOL (M,R) to set a weight for selected edges. Once you have done that the tag is automatically created with the weight information you set. You should also Store Selection for the edges so you can get to them again if you need to adjust the weighting later, as there is no way to select previously weighted components.
