Can't Get Any Objects
Eric Badros
Go to solution Solved by Cairyn,
I'm having difficulty accessing any objects within my document. I've tried SearchObject, GetFirstObject, GetObjects and none of them have worked. I've got the BaseDocument...any advice anyone could provide?
Here's some abbreviated code:
import json
import c4d
import os
from os.path import basename, splitext
def main():
    print("Running main")
    projectFilePath = "L:\\RnD\\dynamic_product_placement\\C4D\\CanTrack_v02_Cineware.c4d"
    try:
        doc = c4d.documents.LoadDocument(projectFilePath, c4d.SCENEFILTER_0)
        print(doc.GetDocumentName())
    except:
        print("Failed to Open Project Path")
    print("where are you ", doc.GetFirstObject())
if __name__=="__main__":
    main()
And then I get the following response:
Running main
where are you  None
Thank you!
Eric
  • Solution
Without trying the code, I suspect you should use some other filter than c4d.SCENEFILTER_0, maybe SCENEFILTER_OBJECTS to actually get objects loaded?
