C4D 2024.5 outline spline (rounded caps)
Go to solution Solved by Hrvoje,
Following RocketLasso video on the 2024.5 update, I noticed rounded caps do not work using a Nodes Modifier on an existing Arc in the scene, and using Outline spline in the SN editor.    However, building the arc and outline spline inside of the SN editor, the rounded caps seem to work fine.   Also if you turn BOTH caps off in the first example, a line gets drawn connecting the ends of the arc, which doesn't happen in the SN example
Built using Nodes modifier, the rounded caps are broken
Build in SN editor... rounded caps work fine
Built using Nodes modifier, the caps are broken
Edited by Jeff H1
added more info (see edit history)
Register a new account
Sign in
    1. 1
    2. 1
    3. 13
    4. 7
    5. 13
