gotcha document scale
Material blend between objects
No reason you couldn't make this work with a material blender and a combination of state, ramp and curvature nodes. You'd have to do it on a per-object basis (so not as slick as the one in Unreal) but it is doable. -
Thanks Hrvoje! I cannot believe that I did all this stuff nearly 20 years ago… I sometimes wonder if I should be re-vamping it considering there is so much kids orientated CGI out there, but I am finding it quite rewarding making it look much more up to date. I might even dabble with AI on it - or is that a dirty word? Still trying to figure out how to add a dirt map to the roof… -
There are some of us which recall the old version, nice to see you reviving old stuff -
@mahmoud morsy Do you have an example of this in action? Looks like jiggle deformer could be what you are after? -
Hi, is it possible to get a material blend between 2 objects like this one in Unreal Engine? https://youtube.com/shorts/8i-Gl4NBVdc?si=PrHAvrMXEGcTxHqv Also is it possible to have a material blend in Y direction on one object?
