Render Time Boolean Effect
Freelancer needed.
Hi. I'm looking for someone who has experience working with CAD models. (I can show you how if you don't) I need someone who can rearrange the parts under a material based hierarchy like in the image below. It would also be great if you can rig parts of the model like doors etc. to open and close. This isn't a one of job. I receive lots of STEP files every month so this will be an ongoing need of mine for the right person. I will of course need you to sign an NDA. You'll find my contact info here www.lightroom3d.com Regards. Cian. -
Reverse Orbit
Well after a little experimentation I clicked on the View>Frame Default and it went back to normal… One of those little glitches I think? @ Hrvoje It was nothing to do with reverse orbit in the preferences since that was switched off, but thanks for the suggestion. -
Reverse Orbit
Maybe reverse orbit is enabled in prefs? Are you using a camera object? It could be that it has negative scale? -
'Cover Flow' effect with Mograph / Fields
Hi, I’m attempting to build a simple Mograph setup which mimic the old iTunes ‘Cover Flow’ interface - a row of tiles which move forward and rotate. I’ve made some progress but am struggling to avoid some of these ‘tiles’ intersecting as the Fields which drive their animation pass over them. Does anyone have any suggestions on how to avoid these intersections - I’ve attempted to ‘push’ the tiles apart when they are rotating but have struggled to find a clean / effective method. I have a feeling that moving the clones axis point from one side to the other might have something to do with this … Any help appreciated. Thanks! CAROUSEL_05.c4d
