There seems to be a bug in the XPresso Vector2Matrix Node
Freelancer needed.
just sent you an email.1 -
Freelancer needed.
Hi. I'm looking for someone who has experience working with CAD models. (I can show you how if you don't) I need someone who can rearrange the parts under a material based hierarchy like in the image below. It would also be great if you can rig parts of the model like doors etc. to open and close. This isn't a one of job. I receive lots of STEP files every month so this will be an ongoing need of mine for the right person. I will of course need you to sign an NDA. You'll find my contact info here www.lightroom3d.com Regards. Cian.1 -
Reverse Orbit
Well after a little experimentation I clicked on the View>Frame Default and it went back to normal… One of those little glitches I think? @ Hrvoje It was nothing to do with reverse orbit in the preferences since that was switched off, but thanks for the suggestion.1 -
Reverse Orbit
Maybe reverse orbit is enabled in prefs? Are you using a camera object? It could be that it has negative scale?
