New Tutorial - Mograph Sound Effector
Weird Issue Happening
you don't have enough geometry for the curvature you're trying to achieve in the cushion so it's causing shading issues. EDIT: I moved the camera at an extreme angle so you can see how there isn't enough geometry to make good curvature. Subdivide the geometry... use a Subdivision Surface or use a Redshift object tag (in the tag: Geometry override / Tessellation) -
I just heard one of the local county police departments started using AI for non-emergency calls to answer questions or direct calls to the right departments. I had friends laid off from the government and government contracting who are finding it hard to get even a "standard" tech job. LOADS of applicants for smaller job pools due to AI removing positions and the unknowns in the current economy. I could see AI eating into those concept jobs and smaller positions where Blender and Maya generalists will be the first to go. I stopped looking at Linkedin because everyone is all of a sudden an "AI Evangelist or AI Creative Director", spending thousands on Veo just to make clips to promote their prompt skills. -
Well I have been working away hard at this and this is where I have got to - I think it's an improvement and getting there Peg's Mansion Flythrough HD v01.mp41
