MTL file not working for OBJ import
Hi everyone, is there a way to maintain or lock the perspective camera focal length after switching to other orthogonal views like top, front, etc? I mostly work with high lens numbers but whenever I switch back from orthogonal views to perspective view it resets back to its default 35mm FOV..
